buick forums   buick forums
Supporting Members do not see ads like the one above and text links below.
andys auto sport
Popular Buicks: LaCrosse | 2011 Regal | Enclave | Lucerne | Roadmaster | LeSabre | Century | Park Avenue | Old Regal | Riviera | Reatta | Grand National
Go Back   Buick Forums > Buick Racing Department > Buick Drag Racing Department
Buick Store Register FAQ Members List Calendar Mark Forums Read
Buick Drag Racing Department Post your Buick drag racing results, kills at the strip, and anything else drag related.
Reply
Thread Tools
  #1
Old April 14th, 2007, 02:41 AM
MrBuick (Magnum)'s Avatar
MrBuick (Magnum) MrBuick (Magnum) is offline
LT1 or bust!
SUPER MODERATOR
MrBuick (Magnum) is on a distinguished road
1995 Roadmaster going Drag Racing!!
Click here to remove this ad.
So I was all pumped about going to the drag strip on saturday, and giving the car a once over, and collecting my stuff... When I grabed the battery and it flopped all about!! I forgot the tray was totally rusted out. And to make things even worse, I broke the bolt on the tie down side. Oh boy, this sucks!!
A little quick thinking, and some real backyard engineering, and I got it tied down VERY soild. All i used were some parts off an old fog light. Didn't even cut anything!! So I hope it passes tech so I can see what this beast can run. A little background:
1995 Buick Roadmaster Limited. Loaded with tomany options. LT1 350.
117,000 miles, a 162,000 mile 4L60E trans, and a very big rust issue. 2.56 rear, no posi. Stock exhuast with muffler delete, stock air box cut all up with a K$N air filter, going to a PVC intake. New autolite plugs, Throttle Body bypass, air pump disable, Beehive valve springs. FE2 caddy rear springs, with AirLift 1000's (rear) helper bags, with 1 valve per side. Menroe Severe Service shocks, with only a small sway bar up front, 235/70/15 street tires, on aluminum rims. I'm gonna see if I need the 275/50/15 Drag Radials I have. I'll take them and put them on if I have traction issues.
The only weight I have taken out is: Spare tire, trunk carpet, rear seat(Maybe, if I feel like it), and a few brackets I didn't like.
The bad thing is, it has a bad exhuast leak at the 3-bolt flange, and at the air pump check valves. So it bogs down some times(I know Matt... But I have all I need to put on headers, i just wanted to wait). The rear tires are about done for, so I'm just gonna BURN 'em up!
It should be about 50*, and a chance of rain...
Hope it all goes well!!
__________________
~Cory Magner "My name is Cory, and I'm an addict."
95 DCM Buick RMS. 14.21 at 91.79 "Jesus", Motor Swap at 85k
95 DCM Buick RMS 13.52 at 99.12 Buffman's car, Fried Ring at 180k
RAISS, Tri-Y's, Pypes X pipe, Spintech Prostreets, 3000 Edge, 3.73's, Eaton Posi, and the rest of the Bolt-ons. Fried #7 Ring. *1/4 mile time was Buffmans best*
And 7 other LT1 B-body's... Is there Rehab for this Sh*t?
  #2
Old April 14th, 2007, 03:22 PM
Buffman's Avatar
Buffman Buffman is offline
Tire Smoking Fury
ADMINISTRATOR
Buffman will become famous soon enough
Re: 1995 Roadmaster going Drag Racing!!
let us know how u do. shouldn't have any traction problesm
__________________
Matt Hoffman
Exhaust Video Burnout!! New Quick Video!
ET: 13.5272 @99.33mph 1.82 60'
^^ Gone 7/12/09, but not forgotten
  #3
Old April 14th, 2007, 09:56 PM
LT1 or bust!
SUPER MODERATOR
Shouldn't is a key word... EVERYBODY seamed to be sliping some off the line. 45* is just cold. I first made some runs on the 235/70/15 street tires. Left them at 35 PSI, which I now know to be a bit of a mistake. Played with the airlifts PSI's, and got a best outta 4 runs: Which was actually my very first run.
I ended up taking out the back seat, and the passengers seat, along with tires, jack, trunk carpet. but left tools, and the compressor.
Weight was starting at: 4220 and ending at: 4190 lbs with me. without me: 4060lbs.
Run 1(street tires)
Reaction: .7602
60 ft: 2.3078
330 ft: 6.4016
ET@594 FT: 9.1377
1/8 ET: 9.7507
1/8 MPH: 73.41
1000' ET: 12.6295
1000' MPH: 85.27
1/4 ET: 15.0446
1/4 MPH: 93.37
Then I switched over to the drag radial's... 22PSI not enough? Cause they seamed to slip just as much as the street tires... Played with the airlifts PSI, burnouts, launch tehnuique, then later tire PSI, and never got the drivers side tire to do a burnout... so the passengers tire did all the burning out, and sliping at the line. I didn't once see them get out the VHT tractor...
Best on Drag radial's: 4 runs into the tire swap, 22PSI in tires, 5/15 in air lifts(I think). It was a solo run. Lucky me!
Run 8(drag radials)
Reaction: .5871
60 ft: 2.2850
330 ft: 6.3308
ET@594 FT: 9.0330
1/8 ET: 9.6488
1/8 MPH: 73.07
1000' ET: 12.4878
1000' MPH: 86.21
1/4 ET: 14.8800
1/4 MPH: 93.90
Trans shifted great, and exactly the same(since it IS, out of the caddy ) as when I took the caddy there. I think that the only thing the drag radials offered, was that they were 2" shorter. Judgeing by the marks at the starting line, everybody was having wheel hop off the line. But I really donno. It was hard for me to tell if I was slipping, since my runs were either agaist a car on street tires, or a car with no freakin' mufflers
Best 60', and MPH, was run 7
Run 7
Reaction: .6410
60 ft: 2.2748
330 ft: 6.3340
ET@594 FT: 9.0488
1/8 ET: 9.6669
1/8 MPH: 72.08
1000' ET: 12.5121
1000' MPH: 86.18
1/4 ET: 14.9070
1/4 MPH: 94.11
Long post, Whoops!
__________________
  #4
Old April 14th, 2007, 10:43 PM
Buffman's Avatar
Tire Smoking Fury
ADMINISTRATOR
Yeah martin will get better for traction. Barely open yet
__________________
Matt Hoffman
  #5
Old April 15th, 2007, 03:59 PM
LT1 or bust!
SUPER MODERATOR
I used a DA calculator , and it said I had a DA of -900. I took #'s from weatherunderground.com . 4 pm, 45*, dew point 22*, IN: 29.90ish...
and judging by my MPH, I don't think that too far off.
__________________
  #6
Old April 16th, 2007, 02:33 AM
LT1 or bust!
SUPER MODERATOR
http://www.csgnetwork.com/densaltcalc.html and something like this to calculate...
__________________
  #7
Old April 16th, 2007, 02:21 PM
Buffman's Avatar
Tire Smoking Fury
ADMINISTRATOR
gee that's like a first at martin. Just imagine what I could have run, a 12 maybe.
__________________
Matt Hoffman
  #8
Old April 19th, 2007, 02:32 AM
LT1 or bust!
SUPER MODERATOR
you think that DA calculator is acruate? It told me the run I made on June 9, 2006... had a DA of 200ft... 60*, 48* dew point, 29.98 In of murcury... I ran a best of 14.97 at 91.81 that day, at 4490lbs, catback, intake, tb bypass, 2.93's, airlifts, beehive valve springs.
__________________
  #9
Old April 19th, 2007, 03:14 PM
Buffman's Avatar
Tire Smoking Fury
ADMINISTRATOR
LOL that Da calculator was off silly DA on your race day was 40 feet
or at least by my calculator
http://wahiduddin.net/calc/calc_da.htm
__________________
Matt Hoffman
  #10
Old April 19th, 2007, 07:42 PM
LT1 or bust!
SUPER MODERATOR
whats the elavation of martin?
__________________
Reply
Tags: , , , ,
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Buick Forums Powered by: vBulletin Version 3.6.10
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
buickforums.com recognizes that "Buick", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. buickforums.com is not affiliated in any way with the General Motors Corporation, Buick or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2010 buickforums.com. All rights reserved.
MADISON ROSS MEDIA GROUP MARKETPLACE
Need products for your Buick? Check out your options at the links below:
custom floor mats | buick performance mufflers | buick performance exhaust systems | racing seats | buick euro tail lights | buick air intakes | buick projector headlights | buick ground effects | buick body kits, hoods and lambo doors | buick body kits | buick carbon fiber hoods | air suspension kits | air suspension parts
