GM wouldn't recommend premium fuel for no reason at all.
Actually, they would, just to avoid any pinging issues in hot climates. In the early 90's Devilles, GM recommended premium fuel for a 9:1 compression 4.9 engine. Most people ran regular with no problems whatsoever; and 9;1 is not a high compression ratio. They probably had some issues in hot climates and just recommended premium for everybody. I would assume that a supercharged engine would definitely need premium fuel but ya never know if you can believe "The General" or not, since they were overly cautious in the past. I'm curious if there are Ultra drivers that use regular.
AL,
There is a common misconception about the correlation of static compression ratio (SCR) and octane requirement. The higher the static compression, the more octane an engine requires. That is not entirely true. The valve timing has a direct effect on the actual cylinder pressure created. There can be no compression until the
intake valve closes on the compression stroke. The
intake valve always closes when the piston is on it's way up on the compression stroke. Different cams close the
intake valve later, or earlier than others. Some of the stroke is used up while the
intake valve is still open. Once it closes, the remaining stroke creates compression. That compression is called the Dynamic Compression Ratio (DCR), and the DCR is what determines octane requirement. Ever wonder why an aftermarket camshaft description lists a minimum static compression? That is why. You get best performance when the DCR is in the 7.5 - 8.4:1 range. Some cams close the
intake valve late enough to require a higher SCR, to get the DCR in the required range. It is possible to have a 9:1 engine with a camshaft the closes the
intake early, require more octane than a 10:1 engine with a late closing
intake. This applies to normally aspirated engines mainly.
Supercharged and Turbo charged engines operate above 100% volumetric efficiency, and their cylinder pressures are like an engine running much higher static compression. Turbo and SC engines commonly have a static compression ratio in the 7.0-8.5 range, because boost brings that up substantially. I've read dozens of stories about people disregarding engine knock, and paying a big price when they crack a ring land, or if they are lucky, simply blowing a head gasket. That includes people who think they can run a higher boost with a smaller pulley, without supporting
mods. You might find this article on DCR interesting.
http://www.empirenet.com/pkelley2/DynamicCR.html
