UtahGuy
- Feb 12, 2012
- Buick
My power windows have not been working in this car for sometime. I always just assumed it was the master switch, so I finally got around to buying one.
I installed the new switch but the windows still don't work. After taking a multi-meter to it I discovered the yellow hot wire is only at about 5 volts. When I connect it to the switch it drops to .6 volts.
The dark blue wire that brings line voltage to the other switches also registers at .6 volts so I know the switch is working.
I'm confident that the ground is in good condition because the lumination wire shows 10.5 volts to the ground wire.
What would be causing this under voltage? Thank you in advance.
