warning chimes on 2011 Enclave
mybuick1
I recently purchased a 2011 Enclave and backed in my driveway to drop off some gear, opening the tailgate. I got in and, forgetting to close the gate, put it in reverse, backed up and crunched my tailgate on the garage door frame (happened twice over 4 months). Hearing all the warning chimes all the time, I checked out all possible combinations. Every combo (tailgate, doors open) with every gear gives four (4) quick warning chimes EXCEPT when the tailgate is open, putting it in reverse cuts the warning chimes down to as little as a "blip". All other gears give full warning. Brought to dealer and checked other 2011 models in stock and it is same on all. Dealer checked with tech support and reported they acknowledge the fault on all Enclaves (have not checked other years yet). They also said there is no fix they have to cure it and will not program one either. This is a safety problem that I believe is their error and must be identified and fixed. I cannot find another blog about this, but after 10's of thousands of these cars built in the last 4 years, I bet this has occured more than to me.
Check the camera view BEFORE backing. If tailgate is up you will know.
Don’t put too much faith in electronics, they are not intended to replace common sense and safe driving skills.
Good luck with Buick customer service. They will say it is designed that way and that there is nothing wrong with it. That will be their final answer. Engineering design flaws that affect all of any year model will not be "fixed". See my thread on the trunk and key fob on the 2011 Lacrosse in the Lacrosse forum.
Thanks for the response Mr. FIXIT, I agree that the response from Buick is "too bad, we screwed up and you must live with it". Or as you say -"CUSTOMER LAST"
Three suggestions before you back up:
1. Look in your rearview mirror
2. Turn your head around
3. Look on the dash (mine says "Tailgate open")
4. Use common sense.
My regal does this. All you can is to turn off the park sensors then it will not cut of fthe bong bong bong you hear if the tailgate is open.
