cadillac
buick forums
The Premier Community for Buick Owners and Enthusiasts
buick forums
andy's auto sport
Verano | LaCrosse | Regal (Old) | Enclave | Encore | Lucerne | Roadmaster | LeSabre | Century | Park Avenue | Riviera | Reatta | Grand National
Go Back   Buick Forums > Past Buick Vehicle Discussion > Buick LeSabre Forum
Buick LeSabre Forum Discuss topics regarding the Buick LeSabre.
Reply
Thread Tools
  #1
Old September 17th, 2011, 05:50 PM
peanuts peanuts is offline
Automobile(s): Buick
peanuts is on a distinguished road
2001 Buick LeSabre wipers won't turn off
Click here to remove this ad.
Started happening yesterday when we got some rain. Turned the wipers on and when I turn it to the off setting above mist, they keep going, although really slowly as if it's stuck on the lowest setting.
Before this happened I started getting a security light when I put it into park flashing every now and then. That light comes on randomly.
Is this a fuse, body control module, something else?
joseph
  #2
Old September 17th, 2011, 05:51 PM
Re: 2001 Buick LeSabre wipers won't turn off
I should also add that the cruise control button won't stay lit whenever I try and turn it on. Perhaps the problems are related.
joseph
  #3
Old September 18th, 2011, 01:06 AM
redmondjp redmondjp is offline
redmondjp is on a distinguished road
Do you have the rain-sensing wipers on your car? You can tell if you do by the black sensor stuck to the inside of the windshield behind the rear view mirror.
__________________
Buick Owner since 1993, 1988 Buick Electra T-Type, 221K miles, sold 7/09
2001 Lesabre Custom, 97K miles, new front hubs already, radio removed for repair
  #4
Old September 19th, 2011, 01:16 AM
I don't think I do, I only see the rear view mirror with its auto dim function and that single black connecting piece. I don't see anything separate coming off of the windshield with holes to allow water into it or anything like that.
BTW, the problem seems to happen when I turn. As soon as I start turning the car, the windshield wipers come on. When I'm going straight long enough, they tend to turn off on their own, and then come back in another turn.
I'm suspecting there's a wire in the steering column area somewhere that is frayed and rubbing against something and shorting anytime I turn a corner (meaning I'm turning the wheel). I have a Haynes manual, and it shows a fuse that's hooked to it. I'll pull the fuse for now and inspect the wires.
  #5
Old September 21st, 2011, 09:14 AM
brucesboat brucesboat is offline
brucesboat is on a distinguished road
I've had both of the problems that you describe. The Cruise control button problem is most likely caused by a defective button. There is a small ratchet cam inside the button that locks and unlocks the switch each time that it is depressed. This cam rotates on a plastic pivot shaft that breaks. I repaired the one on my 2001. My repair on my 2002 didn't work so I permanently locked the button in the on position. New buttons are available thru an ebay store, approx $20.
The windshield wiper problem on mine seemed to be caused by water getting into the motor electrical connector. It would begin acting up after a hard rain. After drying out for a couple of days, the problem would disappear. I pulled the fuse until it dried.
I did have a problem with my airbag light when the steering wheel was rotated. It was a bad clock spring assembly which is mounted under the steering wheel. The assembly carries all the electrical signals from the steering wheel controls. I don't remember whether or not that includes the windshield wiper, altho the way that you describe your problem, it may.
  #6
Old September 22nd, 2011, 08:32 PM
Thanks for posting, it's been several days now since the last rain and it's still acting up, though not as much. When you said the motor's electrical connector, is that underneath the plastic and rubber piece in the engine bay, where the wipers physically connect?
What's involved in replacing the cruise control button, is that a couple of screws from behind to release the plastic cover on top?
  #7
Old September 23rd, 2011, 10:22 AM
It's the electrical connector on the windshield wiper motor which is underneath the plastic cover over the wiper area.
The cruise control button can be pried out from the top, it is simply pushed in place.
  #8
Old September 25th, 2011, 12:11 AM
You know it's funny but the wipers haven't acted up on a few days. Maybe it was water and it finally dried out. Thanks for the tip.
Reply
Tags: , , ,
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Close this column
Buick Forums Powered by: vBulletin Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
buickforums.com recognizes that "Buick", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. buickforums.com is not affiliated in any way with the General Motors Corporation, Buick or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2012 buickforums.com. All rights reserved.
MADISON ROSS MEDIA GROUP MARKETPLACE
Need products for your Buick? Check out your options at the links below:
Buick Lucerne Tail Lights | Buick Parts | Andy's Auto Sport Homepage
