jralston8
- Mar 11, 2011
- Vancouver Washington
- 1999 Buick Park Avenue/1996 Buick Regal 2 Door Coupe
Well, I couldnt find any help anywhere online so I decided to take the day and change all the Instrument light bulbs on my Buick Park Avenue Ultra. ( they were all slowly dying one by one over the past 8 months) I de-soldered the old bulbs and re-soldered new 12.0v 50mA T1 type bulbs from radio shack in their place (part #272-1154) @ $1.99 each x 32 bulbs.
I even fixed my auto climate control unit that kept going dim then bright etc. ( the heavy duty resisters had cold solder, I just removed the old solder with soldering braid and resoldered the resisters back on. So now at night time I am a happy kid
What I changed in all was, All the stock radio lights in the Delco CD/tape/radio - All the lights in the auto climate control unit (includeing fixing the dim display with resolder) - the lights in the seat warmer buttons - the lights for the locks and windows on both from doors - all 4 lights in the steering wheel controls (ugh!) - all the main gauge cluster speedo,tach etc light bulbs - the three light bulbs in the odo/fuel/gage/trip/reset/eng-met those are the 5 buttons to the left of the gauge cluster. Oh! while I had the who gauge cluster out I took it apart and drilled a little hole on the "full" side of the gas gauge and near the "Red" zone on the RPM guage. why you ask? Because both those needles always go all the way around and get stuck under the stop pin(i usually use a Neodymium magnet to push them back around but it started to be a pain in the butt) Hard ware store sells those little tiny magnets for $3.99. Where was I? Oh, the holes in the gauges, after I drilled those little holes I put a little plastic stops about 2/18 I bought from a hobby shop it snapped right into place and looks totally factory.Now the needles cant go all the way around and get stuck under the other stop!😀. Now for the outside of the Park Avenue- I changed all the side marker lights - all the rear tail lights includeing top center inside stop lamp with surface mount LED's made to go right into place of the original incandesent bulb. And to end it all I put in Phillips HID 4,300K Headlights and ballasts for the low beams and 5,000K for the High beams ( u must disable the day time running light to put in HID brights. If you would like I can share how I did this with everyone, in case someone else is having the problem with these bulbs as I did. let me know i will be happy to help u out!
