Engine rattle at cold startup
Click here to remove this ad.
Hi!
I have a 2003 FWD CXL with the 3.4L engine and about 131,000 miles on it. The first startup of the day, I hear a very brief, sharp rattle or rapping sound from the engine area. It only lasts about a second or so then stops pretty abruptly. If I pull fuse-11 for the fuel injectors and crank the engine for 10 seconds or so to build oil pressure, then re-insert the fuse, the noise doesn't occur.
In previous cars that had cold lifter noise, it seems the noise would quiet down a little more gradually, and last a little bit longer, but I am not that familiar with the 3.4 engine yet. I thought possibly rod bearings, but again, in the past it seemed if I had rod bearing problems I would also hear it when I "floated" the engine.... rev it up and just when lifting the accelerator I would hear the noise again. I haven't noticed that with this engine.
I thought I had read somewhere that something in the tranny could produce cold-start noise but I can't find that info again anywhere so I may be mistaken about that. Has anyone heard of that?
If it were something really off-the-wall like timing chain rattling against the cover (if that's even possible in this engine), it doesn't seem that building oil pressure before starting would affect it.
One other detail that I am trying to verify right now is that if I just start the engine and shut it off without allowing it to warm up, then on the first start the following day the noise MAY not occur. I need to do a little more research to see if that's consistent or not. IF this proves to be consistent, then it would seem like the oil is staying put instead of draining out unless the engine is totally warmed up or driven for a while...... not sure what that might point to though... maybe someone else does have an idea?
I am using an AC oil filter since I read that some others may not have an anti-drainback valve, but that hasn't seemed to affect this problem.
The only other noise I notice from the engine after starting is a very faint intermittent ticking sound.... individual tick, not a series of them. It reminds me of the timing gear tick I used to get in my Porsche engine years ago, but I think this engine uses a timing chain, not gears... anyone verify that?
Thanks for your thoughts and input! Nick
